I have for years plotted by using a pen table that looks for references in a dgn file that are referenced by logical name. I set up a different pen table for each type of plot that I'm doing within a plan set so that elements are always drawn one time and placed by defined elements per layer definition. This way I can draw existing planimetrics in the survey file, and depending on what plan sheet this survey ends up on, I can plot it to have a different look by setting a different pen table up for the plot.
The issue I have is a user wants to use a nested reference file in the plan sheets so that he can more easily control layer on-off state in the plan sheets by turning them on or off in the nested file once, and they update in all the plan sheets. I actually kinda like this idea, since it does solve a problem with cad techs being inconsistent from sheet to sheet with certain layers being turned on in one sheet, and off in others. BUT, I can't seem to find a way to get the pen tables to recognize the logical name within the nested file now, so I can't control the way elements look on a plot. The pen table only recognizes the actual nested ref file, not the files that are referenced into that file.
Any Idea how I can get a pen table to recognize a logical name within a nested reference?
Unknown said:Correct.......We are looking for ways to be consistent with level states from plan sheet to plan sheet, and referencing in all the files into a "NEST" file first, then referencing that file into a plan sheet file allows the CAD techs to turn layers on and off in one location and have the layer states be consistent, but by doing that, I lose the ability to plot by logical name then, which I don't want to lose......It's easy to set up a pen table to redirect everything in a file to "Shade" or plot dark as desired, and doing that by logical name makes it simple. So, now it seems like I'm back to looking at other ways to make sure the cad techs have a tool to be consistent in setting layers on or off depending on the type of sheet we are looking to plot.
sounds to me like you
1.You need to set the workspace preferences not to allow changes in the levels from a nested ref attachment.
2. Write some standards that tell drafters what needs to be set to shaded etc and how to set up nested refs files with level overrides or dgn libs etc for what type of jobs and which clients and create specific workspace configs for each standard...
3. Train your drafters to use the appropriate standards and standard specific or client specific workspaces...
4. Still create your custom plt pen tables but link these to custom plots and use the custom plot logical names to select the right pentable for you...by selecting the right plot config name instead... ie survey plan.pltcfg , site plan.pltcfg, geometric plan.pltcfg, alignment plan.pltcfg etc
5. Enforce the standards.
Good, experienced, well trained Drafters love using standards, that is if they are easy to read and well written... I use them all the time... it makes my job easier.. for example our local DOT is really strict about using their long and detailed exacting drawing standards and have published documents and examples for all contractors and staff to use.. and if you dont, then your work is rejected out of hand...
Lorys
Very sorry I didnt mean you needed the training I meant in most cases these issues can be overcome by the cad manager training other users .. I was trying to give you some options in the event that there may not be a solution to the problem... posts often read different to how they were intended to sound.. again sorry about that ...
