Using Pen tables, looking for a logical name to plot when references are nested.
I have for years plotted by using a pen table that looks for references in a dgn file that are referenced by logical name. I set up a different pen table for each type of plot that I'm doing within a plan set so that elements are always drawn one time and placed by defined elements per layer definition. This way I can draw existing planimetrics in the survey file, and depending on what plan sheet this survey ends up on, I can plot it to have a different look by setting a different pen table up for the plot.
The issue I have is a user wants to use a nested reference file in the plan sheets so that he can more easily control layer on-off state in the plan sheets by turning them on or off in the nested file once, and they update in all the plan sheets. I actually kinda like this idea, since it does solve a problem with cad techs being inconsistent from sheet to sheet with certain layers being turned on in one sheet, and off in others. BUT, I can't seem to find a way to get the pen tables to recognize the logical name within the nested file now, so I can't control the way elements look on a plot. The pen table only recognizes the actual nested ref file, not the files that are referenced into that file.
Any Idea how I can get a pen table to recognize a logical name within a nested reference?
  • Unknown said:
    No Problem Lorys.....I am an Engineer that knows CAD, and because of that, I have all the other Engineers coming to me with "requests" to solve common issues they all deal with on a daily basis....this is one that is very difficult to resolve since the downturn in the economy here in the US basically got rid of all the non-degreed technical staff, since that was what companies cut. Now we are having to scramble to find users that are cheap and talented enough to actually help produce, and it's not an easy task. If the pen tables were to just be able to find a logical name in a nested ref file, the issue would be solved, but....again it appears that Autocad has a better solution to consistent layer states.
    Totally understand where your coming from we have the same  problem here in Oz , I have 25 years experience with Mstn and am a  non degree msnt drafter with college or post secondary qualification applied mech and drafting, 20 years in civil ... got laid off in april and no real work since its tough on us old farts ....
    Back to your problem .. you could try and  build some custom menus for specific type drawing plots and  these choose custom plot configs.. not the best fix  but would work and easy to follow for non expert users and would work to some extent with your custom / modified pent table(s),,,?
    Not the answer you wanted but  a viable work around..
    Lorys
    click link to PM me
  • Thanks for the suggestion! I am working on a FEW different techniques to work around this issue....I'll figure out yet another way to make up where Bentley falls flat.
    I hope you are able to find something soon!!! I actually recently sold my company and thought it would be easy to find a new job, I made a slight miscalculation, and it took me 8 months! I guess all you can do is keep the faith that something will happen, I did....and eventually I ended up in the right place. Good Luck to you! Greg
    Thanks for the encouragement,  let me  know how you progress with this , I have done a lot with scripts for custom plotting over the years... feel free to email me offline ...glad to be of any  help I can...
    Lorys
    click link to PM me
  • Can someone from Bentley please chime in? This is a major issue for me as well. Thanks
