Hello all,
I am a newish Microstation User. I just need clarification on plot scale. If I make a fence around the title block, and the drawing is to be plotted at A3, 420mm x 297mm,
do I set the scale at 1.00 to reflect papersize 402.000mm x 285.000mm
or do I hit maximize to get a scale of 0.9596 and slightly different paper size out put of 418.926 x 297.000mm
which one will provide a true scale once printed out?
Some of the dwgs have boundary sheets which the plotter picks up ok, other don't, so I need to work out what to plot at.
Cheers for any help.
