I am trying $FILES$ to generate the file name with extension. I found that with the same pen table there might be two different outcomes between ProjectWise and Local drive.
When the DGN uploaded to ProjectWise server, the Document Name will be the "file name + .DGN", and the Document Description will be "file name". So,
how to set the pen table text substitution that point to ProjectWise's Document Name but NOT the Document's Description?
Environment: MS V8i SS3 08.11.09.714, ProjectWise Explorer V8i 08.11.11.574
A better place to post your question would be the Printing and Plotting Forum.
Thanks. Actually I am not that sure if it is the pen table problem. It might be Microstation's problem.
From the below screen capture, you can see the current file path is PW:\\...\....\FILE NAME which has no extension.
But some of us show the extension.
Answer Verified By: clever_anthony
