Raster Options
Good morning,
Is there a way to save your print - raster options? I keep having to go...
File -> Print PDF -> Settings -> Raster Options and then changing the raster quality to 100.
I want to save the default to 100 instead of 50.
  • You can find that setting in the Print Driver settings. In the Print Dialog go to <File <Edit Print Driver Configuration. Under the Raster Printing header you will see Raster Print Quality. Set this to 100. Just a warning, your file size will probably be pretty large.
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
  • Hi Eric,
    I agree with mwlong warning about output data size, to double the quality will produce substantially (I guess 4 times) bigger file.
    Usually 50% quality is good enough, but it depends what type of rasters (binary, orthofoto...) and on what printer you print. I recommend to print a few samples using different quality factor and to decide what valua is "good enough".
    With regards,
    Jan
  • For bentley pdf driver / plot cfg
    Another setting to change that will make a huge difference is under the driver  properties
    The Default compression is ZIPPED change this to JPEG and you'll get a really big difference and wont need to compress your pdfs externally anymore with
    Acrobat PDF full version ( not reader) or some other pdf compressor tools...
    I found this by trial and error and didnt  realise it would make such a huge difference especially  with rasters attached...
    Lorys
    click link to PM me
    Ah yes, I forgot about that option. Depending on what that is set to your file will change size significantly. There is also a Resolution setting under the Advanced tab that will have affect on size.
    Eric:
    Another setting you may want to check that will not affect file size but can cause problems if you use Masking in you .dgn file- disable the Enable Measuring under Driver Properties tab. If this is enabled and you have a lot of clip masking most likely you will not be able to create the pdf from the .dgn. I know this should be brought up in a different post but I just thought of it and it will help you avoid headaches later on.
