I am having problems with my Print Organizer that is rather frustrating that I could use any help on determining a solution. Currently I try to open a .pset which works but I seem to be unable to do anything (add files, view preview, etc.) past that. A script found below is what pops up when I do try to perform any functions within the Print Organizer. Please note I found a solution on the forms about fixing and/or replacing the NETFrame work which I did but to no help. I currently am running Microstation V8i (SELECTseries 3) - Version 08.11.09.459. I have also tried using the Print Organizer in GeoPAK but am unable to get it to work there.
Exception encountered inside
[WorkerMicroStationProxy.SetPrintSetSchema]
- There was no endpoint listening at
net.pipe://localhost/fc721c00-df58-4c81-afea-c3906468b1de
that could accept the message. This is often caused by an
incorrect address or SOAP action. See InnerException, if present,
for more details.
Any help on this would be greatly appreciated.
I'm having the same issue. Anyone know of a fix???
Recently had this same issue. Resolved by running the program as an Administrator.
running which program as an administrator? Microstation?
Lorys
Yes. MicroStation is where the problem was diagnosed. However I was also experiencing the same problem in PowerGEOPAK. Right click on the desktop shortcut, and "Run as administrator".
