I am using Interplot organizer and need for raster images to be plotted in gray scale. What is the best way to accomplish this? Can I do it with design script and if so how?
I know this is a really old message, but if you stumbled across it looking how to make rasters grayscale on a ProjectWise i-Model Composition Server for PDF server, like I did, you can use this variable in a microstation config file (I have it in a PCF) or in a Managed Workspace variable and it will work too.
Changing the iplot.cfg file on the server will work, but it will make rasters for all projects grayscale. We wanted just one project.
Update:
In ProjectWise InterPlot Organizer 10.00.01.22 and higher, we have added the ability of adding IPLOT config variables as IPARM environment variables. These will take precedence over those in ip.cfg and iplot.cfg. The entry in the project specific settings file, will look like this:
When used in conjunction with a rendition it should produce the desire affect on your raster images.
Oh nice. Thanks.
