I have DWG files we are trying to plot with iCS PDF Renditions, within the DWG's are Mutlileader text labels. When these are opened by MicroStation they come in as cells name MULTILEADER. Within the cell are two shapes one for text background wipe area and an arrowhead. I am attempting to create a design script to change the fill on the text background shape to (255,255,255) and the arrowhead to (0,0,0). The issue is the text background shape fill_color coming from the DWG is NOT a number from the color table, it is set by an RGB value. I cannot perform a conditional IF selection on color or color_fill by RGB, so these shape elements shapes cannot be isolated in the design script to change the color. Is there any way to find elements by color with RGB values in an IPlot design script?
I also have this problem. I can't group select multileader cells from AutoCAD or group change the text attributes font etc... Is there any way to manipulate multileader elements from AutoCAD without doing them one by one or redoing them all as Notes. This is a really time consuming task when working with dwg derived files.
