It takes a long time for me to print using Print Organizer in Microstation SS2 with ProjectWise SS4. When I add multiple sheet files, Microstation re-downloads the support files associated with the PW managed workspace for every file. This takes a very long time and seems unnecessary. All of the files are located in the same directory and have the same managed workspace settings. I've tried setting MS_PLT_PWWORKSPACE_OPTIMIZATION=2, but it has no effect. What am I missing?
After starting Print Organizer and adding the first DGN, open Task Manager and examine the ustation.exe processes. You may need to go into Task Manager Options and ensure the Command Line column is displayed. There should be two ustation.exe processes; you are interested in the one that contains the -ws_USTN_WORKERMODE argument. Look for the -wc argument; it specifies a path to a .cfg file in the workspace subfolder of the PW user working directory. The path may be truncated. Hopefully enough will be displayed to uniquely identify the .cfg file. If not, you may need to use a superior task manager application, such as Process Explorer (technet.microsoft.com/.../processexplorer.aspx). Sample screenshot attached.
Make a copy of that .cfg file somewhere. Now add the second DGN to Print Organizer. Does that ustation.exe process automatically restart? Does it restart with a different .cfg file specified in the -wc argument? If so, make a copy of the new .cfg file and compare them. Are they different? If they are different, that's why Print Organizer is re-downloading the managed workspace for each DGN -- it believes the workspaces are different. Comparing the .cfg files may give an indication as to why. Something unusual in the ProjectWise configuration blocks would be my guess.
