Cannot create a 3D PDF rendition from a .dwg file. Print sheet model only.
I am trying to create a 3D PDF rendition from a .dgn file. I am right clicking on the file in ProjectWise> Create rendition and then selecting the 3D PDF profile I have created in ProjectWise administrator.
My problem is that the rendition created only shows the sheet model and not the 3D design model. Ideally I would like both within the plot however it would be ok to print just the 3D design model. What settings do I need to change in Interplot Organizer to print the design model rather than the sheet model?
I am changing the .set model used within ProjectWise within interplot organizer.
Michael
