Microstation Printing takes 15-20 seconds. All other programs print fairly fast. Everyone else in our office has no issues with slow printing (2 seconds) with Microstation select series 3 (08.11.09.459). I believe had the same problem with SELECT series 2. We have 5 printers at work and one of the older printers hp8150a would print ok (5 seconds), but this one has broken down and the rest of the printers print very slow. Since it's just Microstation that prints slow, could this be an issue with printer drivers? I sent this to our IT several times with no reply, I imagine he does not know how to fix it. We are all on the same type of network, so not sure what is the problem.
I have a dell T1650 i5 system 64 bit, 8GB RAM, windows 7 and NVIDIA Quadro 600 video card.
thanks
sounds more like print spooling or print server issue...
is the canon a wide format hpgl printer... or is it postscript
are you windows assigned drivers to the printer default generic windows install or are they from the printer manufacturer this can make a big difference...
these are the ones that after you made the pdf you send the pdf to printer by selection it ( it being the driver for that printer)
After you made a pdf locally and then send it to plotter open the plotter icon and see whats going on like counting down etc or spooling etc... talk to you IT guy....
Lorys
