I changed from HP Designjet 4520 HPGL/2 to HP T7200 (using a HP T7100 driver).
While most prints come out fine, some user's prints have text printed as on a low-res fax document. Lines appear to be fine, if somewhat edgy. The logo is flawed also. It seems as if it's printed in 100dpi, instead of 300 or 600dpi. I have a RIP, and I can see that what comes into the RIP, is already flawed.
I suspect the user's setup, because it's a minority that has this problem. And using the PDF-printer, and then sending the file to the printer, works fine.
Any ideas where I might start to look?
Unknown said: I changed from HP Designjet 4520 HPGL/2 to HP T7200 (using a HP T7100 driver). While most prints come out fine, some user's prints have text printed as on a low-res fax document. Lines appear to be fine, if somewhat edgy. The logo is flawed also. It seems as if it's printed in 100dpi, instead of 300 or 600dpi. I have a RIP, and I can see that what comes into the RIP, is already flawed. I suspect the user's setup, because it's a minority that has this problem. And using the PDF-printer, and then sending the file to the printer, works fine. Any ideas where I might start to look?
go sit next to those with the problem and watch them as the set up to print, take careful note and look to see if the have the rasterize button ticked on if it is then this is the main culprit..
Mst remembers print settings so if they used it once like that it remain ticked , untick it and tell them never tick it again and if you want rasterization then only use the bentley pdf driver not windows printers... personally I never use windows printer direct from mstn.. and train all fellow users to do the same ..why?
Because today we dont use paper for clients very much except long plots or roll plots we only send pdfs so you mays well get used to always making the pdf and if you need paper print that as its what the client will most likely see so its best to print to mst to pdf and pdf to paper...
Lorys
