Print Organzier will not screen properly
Print Organzier will not screen my aerial back to 20% or 40% when I do the batch plotting but, when I plot each sheet individually it works fine(all 150 pages). I have messed with a couple setting in the properties box but it would change things that would not need to be changed. I have messed with the global raster image setting to screen back to what I like. I am pretty sure it is a batch plot setting somewhere I have not clicked.
  •  yes I have attached all my current setting. and it has grayscaled things out that I did not intend to grayscale out
  •  please see attached images
  • Unknown said:
    (Please visit the site to view this file) please see attached images
    Not  sure what your asking , I cannot find any button or setting with "screening" there are several  buttons  for aerial or raster involving % 'age,  2 are contrast and  brightness  another  is the  resolution as a percentage  but  just for the raster  it doesnt change the resolution of the vector ie lines and text...
    There are a couple of things  I would change  if I were you.. first  I would make a custom pdf.pltcfg and set all the settings I wanted in there  and use it for the  batch printing default  driver..
    your screenshot middle pane  under raster options  has print raster  grey scale ticked  this makes you raster grey instead of colour this is not "screening"...
    Left panel  untick rasterised, this  not needed  you have already  set it to use transparency  in the print  settings which is the only  reason I would use rasterised  in pdfs is from the printer settings not the  print dialog,  it works much better  quality  prints this way,  why ?  not sure but tests with it on and off  prove that  we should avoid the tick rasterise.. it must  make a difference with printing direct to printer with windows system printer.. but we never do this anymore  we always  print to pdf first then  bulk print the pdfs to the  printer for hard  copies....saves a lot of time and no dud prints as  you can preview all the pdfs first and what are  you going to give your client ? pdfs right?
    oops spoke too soon  I just found screening  under the  pen table  so create custom pentable and add that to you custom pdf.pltcfg and you'll have your screening  as well
    you have  to choose raster  then in output optoins  you'll see the screening and a slider or % bar available... once you have set these  you have to reload your printer driver and  hopefully  you set the path etc to use the desired  pentable inside the  pdf.pltcfg file  so its auto loading the  pentable... if you call this  printer.pltcfg  Something  easy to recognise  like
    50RaSscrningPDF.plot  (for 50 percent  raster screening pfd)
    so easy to remember what its for easier.. and share with others on your network...
    Lorys
    click link to PM me
  • Lory, ed,
    sorry for the lack of the explanation of what I am trying to accomplish. I was trying to print a full set of plans that are one pdf (150 pages) and not 150 separate pages. one of the pltconfig files has this setup "CDOT-PDFHighQuality_V8i.pltcfg" but when I use it I can never get the raster image configuration to work right. But if I use the "CDOT-ROW-DefaultPrinter_V8i.pltcfg" the raster image configuration works out great but prints 150 separate pages. I used your suggestions and it worked all creating one pdf of 150 pages...
  • Unknown said:
    Lory, ed,
    Thats great you  fixed it  with my suggestions  but now I see your real problem is the  format  for the  pdfs out put not  to be  multipage
    If you  use print organiser this is easy to define and it gives a preview of the outcome if you change the settings
    with the single  separate pages you have option to change the output names and  preview
    Lorys
    click link to PM me
Reply
  • Unknown said:
    Lory, ed,
    Lorys
    click link to PM me
