Hi
I’ve created and saved a default print style that works and is to be used for a set of drawings under a different server. However it seems that the option is not given when a drawing is opened through projectwise. I am unable to even select the print style previously created. I’m thinking that drawings under projectwise operate with definitions taken from a different file path. If that is true, then would replacing the default style with the created one work? Only, I’m worried that in doing so it would affect all projects under the other server and would preferably like to avoid this without further information.Perhaps there is even a way to change the settings so that a print style may be created.
If you could, would you please assist me with as to how I may proceed with this; or is it an option projectwise simply negates the use of?
I am currently operating through Powercivil SS4. and the listed drawings are of the .dwg format.
T.Y.I.A.
Unknown said:It seems that the option is not given when a drawing is opened through ProjectWise
Are you one of the ProjectWise (PW) administrators in your organisation?
