Using the Print Organizer in MicroStation V8i, how can I print from multiple shapes in the same file.
I have a square shape on level 54, color 4, line style 1, weight 0 and use these settings
in the Define from shape dialog but I am only getting a plot from the first shape on the
drawing and not the other 15 square shapes. Can it be done?
Hi Jan, There you go an article which explains how plot organizer works in this cases: communities.bentley.com/.../7203 Hope this helps, Best regards
