Poor Quality PDFs in the Advanced Print In GEOWEB
Call for Help!
We are having extreme difficulties in obtaining an acceptable standard of PDF form the advanced Print command in the GEOWEB.
The end users are wanting to use this function but the end result is unusable.
Has anyone suggestions on how we can fix this problem? We have raised a service ticket but as yet have had no feedback.
Below is a small clip from the PDF
Thanks in advance Cheers Kim
  • I have not used GEOWEB, but I assume  msnt is the engine and  printing to pdf is  done through a  plot.cfg file  or driver... then examine the  settings in the  driver for  what default resolution its using and  change it to a higher value also see if the compression algorithm is  set to the default  zip if so change to jpg , use the pull down bottom right corner this will make higher res pdfs smaller in size ..... well they do in microstation....
    Lorys
    click link to PM me
Reply
    Lorys
    click link to PM me
