Projectwise Plotting Drivers
What is the ETA on the CONNECT mid-volume and high-volume driver packs for Projectwise Plotting?
The driver pack does not have any plotter drivers that we use in our organization and we need the other two to utilize Iplot.
Parents Reply
  • ProjectWise InterPlot Mid-Volume Driver Pack and ProjectWise InterPlot High Volume Driver Pack CONNECT Edition v 10.00.00.18 are now available from the Fulfillment Center.
    The ProjectWise InterPlot driver packs are a collection of wide format output device drivers to be used with ProjectWise InterPlot. The driver packs provide enhanced support for selected models of medium enterprise wide-format printers from vendors such as Hewlett-Packard, Océ, and Canon, as well as create output in a wide range of raster formats. The drivers are optimized for printing complex engineering drawings and high density raster files while being totally integrated with the Microsoft Windows printing system.
    The ProjectWise InterPlot driver packs added support of Windows Server 2012 R2 (64-bit) and include support for Windows Server 2008 R2 (64-bit). Windows 8.1 (64-bit) and Windows 10 (64-bit) support was added for print client operating systems and include support for Windows 7 (32-bit and 64-bit).
    New ProjectWise InterPlot Mid-Volume Driver Pack CONNECT Edition drivers were added for the following devices:
    •Canon PlotWave 750 and ColorWave 500
    •Hewlett-Packard PageWide XL8000, XL5000, XL4500 and XL4000
    A new driver was added to the ProjectWise InterPlot High Volume Driver Pack CONNECT Edition for the following device:
    •Canon PlotWave 900
    In December, the ProjectWise InterPlot Driver Pack and Raster Offline Driver Pack (v 10.00.00.08) CONNECT Editions were released with updated operating system support.
    The ProjectWise InterPlot Driver Pack CONNECT Edition included new drivers for the following devices:
    •HP DesignJet T7200, T3500, T2530, T2500, T1530, T1500, T930, T920, T795 and T520
    •Canon PlotWave 340 and 360
    Note: ProjectWise InterPlot driver packs version 10.00.00.08 and above are not compatible with versions of ProjectWise InterPlot Server prior to 10.00.00.42. You must upgrade to ProjectWise InterPlot Server CONNECT Edition prior to installing any of the ProjectWise InterPlot CONNECT Edition driver packs.
