Printing Wrong Line Styles Through Print Organizer 08.11.09.832/08.11.09.878
I am having a reoccurring problem when plotting through Print Organizer. Every so often when I plot a set using PO, some line styles do not print correctly even though they are correct in the file. If I plot the same files using traditional plotting methods and NOT using PO, the sheets print the line styles correctly. If I use PO but have a file open, all sheets EXCEPT the file that is open at the time print wrong, the file that is open at the time prints the line styles correctly. This is a high priority for us as a deadline is near. Any help would be appreciated.
