I am trying to convert very large .dgn file sizes to a smaller pdf size to make uploading easier on my company's website. I have be able to reduce it a significant amount by changing the dpi, but I am not very familiar with MicroStation, so I am looking for some help. Does anyone know of a way to reduce the file size? I have been using Adobe and Bluebeam to do this.
Unknown said:I've been fighting this same issue for years. Can't seem to find the sweet spot for drivers on the Bentley side. Using Acrobat to 'SaveAs Reduced Size' PDF really helps. Lately I've been getting higher quality rasters (GIS aerials) and have started to use Acrobat 'SaveAs Optimized' to retain more pixels for quality. Optimized gives you some more exacting sizing for the raster portions of the PDF.
Aha! you have large rasters ie aerial photos, look inside your pdf driver the default compression is ZIPPED, if your using rasters a lot change this with the pulldown to JPEG it will compress further.. I sued to do what your doing using external Adobe to compress, but it just uses the JPEG compression equivalent , so if you used the default zip internal compression setting you'll get big difference after with adobe compress.. but if you change the setting to jpeg the file will be compressed to max already and the adobe compress wont change much unless you have changed the resolution in the adobe compression in that case change the resolution of the file and the raster too in the pdf.pltcfg... I example driver I sent has all these settings but you can tweak them further.. .. I would also turn off line line weights or remap to weight 1 as a supper compressed lower res pdf will be zoomed in a lot by viewers and the lineweights also get magnified... ( check with control 5 toggled in adobe reader when you've zoomed in a lot you will see what i mean) .. BTW if you make new drivers just copy paste rename and edit the new renamed one so you always have the pristeene original to go back too, plus it makes sense to a have a logical name for those special pdf drivers...
Lorys
For me, I think that the FoneDog PDF Compressor is your best choice. The security of our files is of great importance. FoneDog PDF Compressor is 100% security guaranteed. In addition, it compresses my large pdf files just in a short time. It really saves much time for me.
You can try it by yourself. If you have any questions, you can contact me and I'm very glad to answer them.
Ethel S. Wunder said:I think that the FoneDog PDF Compressor is your best choice
FoneDog mention several operating systems but not Windows. Since all MicroStation users have Windows, I don't see that FoneDog would be any help.
Ethel S. Wunder said:you can contact me
That would be hard to achieve. You didn't leave any contact details. Your Be Communities profile is empty. Or are your contact details, perchance, the same as the FoneDog contact details?
