I'm having trouble with printing. My "print" icon does not bring up the print window anymore.
 When I hit the "print" icon", it  brings up the "Fence" window. (I already selected the fence.) I also tried the "print" under the "File" pull down menu; same problem. I can select "print preview"  and print a drawing using that window, but you can't format the print that way.
I hadn't used MicroStation V8i in about 6-8 weeks. I had no trouble printing before now.
Any ideas?
