When I hit the "print" icon", it brings up the "Fence" window. (I already selected the fence.) I also tried the "print" under the "File" pull down menu; same problem. I can select "print preview" and print a drawing using that window, but you can't format the print that way.
I hadn't used MicroStation V8i in about 6-8 weeks. I had no trouble printing before now.
Any ideas?
if you using dual monitor try to turn off 1 monitor and then hit print it will bring up print dialog window on same screen . hope it fix the issue .
I seem to have this same problem except in the newer CONNECT Ribbon menu system. How do I go about fixing this in CONNECT? Thanks!
