This pertains to migration from v8i to Connect. I've been running Connect for a week now and dealing with miscellaneous things.
Most of my projects use raster images attached to the master model, referenced in a sheet and transparency modified in the sheet. Most of them work fine, but I have one file that doesn't work. When printed, it ignores the transparency I've set for the raster image and just prints it 100%.
Connect r17 10.17.2.61 self-employed
simple answer dont use CE , log a SR with bentley send a copy of your file to bentley and go back to using ss4 or ss3...
I believe its too bug ridden to be of any production office use at our consultancies level ie roads , infrastructure etc when batch production and consistent lookin prints across hundreds of plans in a print set as well as multiple projects for the same clients they should always look and feel the same if you used standards.. and standardised printer drivers and pentables...
Lorys
I am running SS10 and get the same thing. I have not figured it out yet, but have narrowed it down to something in the seed file. If we use our state DOT seed file, then I have no issues, but If we use our County seed file then the transparency will not work unless we print rasterized.
Seems like a workaround is to not use transparency or print as "rasterized" and to increase the brightness in the Raster Options portion of the Printer > Settings. Moving the Brightness to 100 made my print look about the same as what it looked like on the screen when I changed transparency to 80 for an aerial image jpg.
