Hello, I know for the print organizer we are able to save the Pen Tables we are using per file, what I would like to also be able to do is save the Printer Driver per file as well.
For example I print my plan sheets using a color driver (.pltcfg) and I print my cross section sheets with a non color driver. Is there a way to save the driver per sheet?
Thank you
No. The print set requires a common printer.
Using CONNECT Edition, I would suggest using the sheet index. Select your cross section sheets from the index, select your color print style, and print. Then select your plan sheets, select your black and white print style, and print again. No need to maintain PSET files that get out of date.
can you specify how it can be done in V8i too?
There are still more V8i users than CE...
Lorys
Currently Using V8iss10 (8.11.09.919)
and dabbling in CE update 16 (10.16.00.80)
and now
Pwise Administrator ( yeah I passed the training course!)
I know this is not good if you are worried about the number order but:
You can just create 2 Print Organizer (.pset) files. One using the one PenTable, and the other with the Other PenTable! Separate the files into the appropriate pset files. If possible, you could combine the Pentable settings into a single PenTable.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
But you're right - that DOESN'T work very well If we need our sheets in order (and take advantage of sheet numbering via text substitutions/cfg vars in our pset). And combining all the different pen table settings into one SuperPenTable is neither simple nor practical in many cases.
Are there any other workarounds for using more than one pen table, or for controlling the starting sheet counter in Print Organizer?
MaryB
Microstation 08.11.09.919Power GeoPak 08.11.09.918Power InRoads 08.11.09.918
The long and harder way to do it is to use Windows to locate the printer and add it, but sometimes it doesn’t work correctly. You will have to know some information like what are the name of the printer, Brother hl-2280dw wireless setup and the IP address of the Wireless. You can, get that info from the Printers Menu, normally under reports.
When it comes to the best quality printers, Brother is the most preferred choice among users. It comes up with exclusive features that help you to perform your official tasks uninterruptedly. Despite being responsive, you may come across a message displaying Brother Printer Offline.
