I get ready my paper space for plotting, I have a couple of dynamic views in place, with visual style of hidden line and some dimensions/texts in the paper space, if I choose to print to pdf (thru pdf.pltcfg), now in versión 08.11.09.833 SelectSERIES 4, automatically choose Rasterized. I don't choose this options often because:
In the paper space of MicroStation look like this:
But in the PDF:
No dimensions at all.
I did the test with SelectSERIES 3 and not problem:
What could be missing right here?
Is there any work around to fix this or I should keep with SelectSERIES 3?
Versions used for this:
Just for the record, when I choose a portion of the paper space to print, with a fence for instance, the dimensions are visible/printable.
Any hint to fix this, or perhaps to address to Bentley, will be much appreciated.
Don't know much about that rasterized format stuff, mine has always been set to Force Non-rasterized. Never had anything not plot, I work in a fairly broad field of disciplines.
The usual culprits are non-print level, construction lines, white color, ?, don't seem possible. You could try printing with the same plotter file that SS3 uses. Or try one of mine linked here.
I do not recall there being an issue with dimensions in MicroStation SS4. Would it be possible to send me your data via a private email? As a workaround place your fence on top of the sheet and select "Fence" instead of "Sheet" under "Area:"
Before posting this, my check list:
I try also your sugestion with no diffenrence at all.
Following your suggestion:
Also for the record:
We received your data through the SR you filed with Bentley. We are in the process of investigating the issue, will post our findings.
