I am using the print organiser in PowerDraft V8i to print multiple files to individual pdf files (using pdf.plt)
All is good except I keep getting a filename, date & time stamp in the bottom left hand corner which I don't want. I cant seem to find the option to disable it.
Can someone point me in the right direction?
can you check that "border /filename /time /text_height=0.35" is commented out in the pdf.plt-file?
;border /filename /time /text_height=0.35
Andreas
Answer Verified By: SB Owens
Ahh yes that line is within the .plt file
Will removing it solve my problem?
It should be enough, to have it commented out with a semicolon at the beginning of the line
