I'm having an issue with a set of drawings when I try to print it as a TIFF. Every time I do so, it brings in elements into the drawing that are not actually there. It does not do this when I print the drawing as a PDF. Any suggestions???
Hi Joseph,
there are important inromation missing in your question: What MicroStation version do you use, what printer driver (and with what modifications). Can be some example shared ot at least to provide captures of original file and the result?
With regards,
Jan
Using V8.11.09.459. Using the MS Tiff driver with no modifications. Is there a way to post a drawing to this thread or do I have to post a link to it?
To attach a file: Reply to message. Right below where you are entering your response select Insert->Insert image/video/file. In the From field, select "File Upload", Click on Browse and locate your file and click on Open, then OK.
