Priority shift when printing to .pdf
I'm using Powerdraft. A colleage of mine made a new layout. With this layout the printing to .pdf goes wrong.
The priority of the drawing becomes a mess. In the Powerdraft layout everything seems fine, but in the pdf its wrong.
The shift in priority is not by layer, but by element. How can I solve this problem?
  • If you are not using a MicroStation pen table or a design script, the priority you are seeing in the display should follow on the generated pdf or piece of paper.
    It might be difficult to see in the preview but is the same occurring there?
    Printing to .pdf using a Bentley driver or a system driver?
    Is this occurring on multiple machines?
    What version of PowerDraft?
    Can you provide a sample of the issue to include the generated .pdf file?
