faceted edge when clipping DV
When a circle element is used to clip a reference drawing model that has a DV referenced to it, the filled wall as shown in the first image is faceted in the printed PDF or image.
The edge displays correctly on the screen (second image). The print rasterized option is enabled to achieve the proper result.
Is there a setting somewhere that would fixed this?
Gary
  • In the print dialog, take a look under Settings->Visible Edges Settings->Method. The default is "Fast". This method provides quick results by approximating curved surfaces with a facetted representation. This can substantially reduce processing times for large models. Exact - This method produces an exact representation of the curved geometry, but may require substantially more processing time, especially for large, complex models. May also want to look at Accuracy. Help has good information on it.
