AS noted CEU6 is not honouring Full Sheet mode. I am trying to print an A1 drawing to A3 using a custom pltcfg, which has Full Sheet Mode set to True. I am having to click Maximise Print Size in the print dialog to get this to work.
Anyone?
Full Sheet means a paper size is used without margins when ticked.
When in the sheet model the Size is defined as A1, the print dialog will start with a A1 paper size. When changing the paper size to A3, the scale has to be adjusted. This can be automated using in print Dialog: Settings – Printer preferences , enable maximize on new plot area.
Thanks.
Is there a way of adding this to the pltcfg file?
