Print Organizer Won't Print In Color
I edited my pen table to print Color 36 as an RGB color. If I use File>Print it plots in color like I want it to. If I use print organizer, assign the same pen table, it prints black. I'm sure I am overlooking some setting. What is it?
thanks
  • Also, we just installed Microstation on this machine a week ago.
  • The only thing that jumps out at me is the screenshot for the Advanced Tab. It shows you are utilizing a Project Workspace "!Water". I do not define these in my PO sets. Do you need to have one defined? We always open our project and run PO from inside that session so we are already in the correct workspace. That workspace could have the same line style name as another workspace but the styles could be different (from the resource files)
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
  • I'm not sure. It must have defaulted to !Water since that is the project I opened with? We are a city, so each agency has its own particular standards. !Water is water utility related.
    I am trying different workspace configuration variables, like MS_PLT_ENGINE_CMDLINE_ARGS and MS_SYMBRSC. so far no joy, too many variables to check for an ignoramous like me, so I am going to export the workspace configuration from a working machine and try the .ucf on the new install.
    thanks for the assistance. if I solve it I will let you know what worked.
  • It should not default to anything unless there is some sort of configuration variable is able to control that. I would just switch the Workspace drop down to be blank and try printing. If the issue still persists then you need to check if a pen table is being loaded or if a different .pltcfg file is the cause.
  • thank you. I will look at that. that screen capture was from a working machine, though - we are trying to use the exact same print style file from the machine that works, and the one that doesn't. maybe the other is *not* using !Water.
    Copying the ucf from a working machine to the new install didn't work. in fact ...
    setting MS_PLT_ENGINE_CMDLINE_ARGS and MS_SYMBRSC to networked standards files changed the erroneous line from the (bad) custom linestyle to linestyle 0. copying the entire ucf changed it back to plotting the wrong custom line.
    I'm sure it is something simple, just wish I knew what.
