I am moving from Windows XP to Windows 10 to run Microstation and wish to transfer my plot file over, can anyone tell me how to do this please?
On 21 Nov 2017, at 14:41, George A. Martin <bounce-47D3A6C3-A9C2-4AEA-B7D7-AEEA199FFFFD@communities.bentley.com> wrote:<Bentley_5F00_Communities_5F00_RGB_5F00_Stacked_5F00_244x88-png_2D00_125x44-png.png>Update from Bentley Communities[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]RE: Upgrading Microstation to Windows 10 from Windows XP<4TNXDSRAI5NL-jpg_2D00_70x70x2-jpg.jpeg>George A. MartinHi Peter!As Jan asked, Could you clarify "Plot Files"?The old ascii based .plt files still work. Although the newer xml based .PltCfg have newer and more robust features/settings. So it would be to your advantage to convert the .plt to .PltCfg.Pen Tables work as before no changes.If you are turning out specific output files (.000) and sending those to specific plotter. They should still work, as long as the plotter is supported and the plotter supports them.There were changes made to Batch Plotting, it is now Print Organizer so you may need to generate a new Print Organizer .pset to replace the old Batch Plotting filesI-Plot files?Did this answer your question?Verify it as the answer or Reject it as the answerView online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.Flag this post as spam/abuse.
Hi Peter!
I-Plot files?
View online
