I use AECOsim Building Designer V8i and have a problem with my printed PDF:s. I have a number of drawing extractions on my drawing. I´ve used the clip reference tool along a circle. Everything lookes good exept the "smart solid/associative region". In microstation it lookes good but when I print the pdf it lookes bad. The picture below displays my problem. If I print it Rasterized it looks good but it takes some time to print everything rasterized... Any suggestions?
Try setting "Enable Driver Clipping" to "False" under "Base properties->Advanced while editing the .pltcfg file. Save and reload .ptcfg.
If it doesn't help, try another driver like printer.pltcfg or pscript.pltcfg. this test will let us know if the issue is specific to pdf.pltcfg.
You can also send me a private message with a set of data that shows the issue and I can test. BTW, what exact version of AECOsim are you using?
It works! Thanks alot!
