Microstation 08.11.07
What is the different between .PLTCFG and .PLT?
I have been having problem plotting files in png, wmf, tiff, formats "Printer driver configuration file..... is not valid" "Raster compression value can not be 8, or 18, or 28 depending on print output format.
Could not find 'riff.pltcfg', but found 'tiff.pltcfg'. Maybe it is one of the same [just a typo]. It works. So, are you recommending me to replace my old '.plt' with '.pltcfg'? I have been using '.plt' for years. Never pay any attention to it.
Thanks.
Thanks for pointing out the typo. I would suggest you move to using .pltcfg files instead of .plt. Bentley will continue to support both formats but the .plt format files will not be delivered.
