I was wondering if there was a command that can be put into a Design Script that will run a separate Design Script. What I'm trying to do is utilize a Design Script provided by one entity but also run some of the commands required by my office. Instead of adding multiple lines of code in multiple delivered Design Scripts, it would be easier to add one line at the top/bottom of the files to have our file executed.
Unfortunately not at this time.
Answer Verified By: Sean Duphily
