Placing text in multiple printed pdfs. Each drawing pdf comes from a sheet model. In the border of each are a few pieces of text; it is wanted to read these from a single instance in a single table, and have them replicated in each sheet model and in each pdf. Presently, pdfs with blank hardcopy space are printed and handwritten!
Not sure that I understand the question but I will try to take a stab at it.
MicroStation printing cannot add text to the generated output file or plot. Both MicroStation pen tables or a design scripts can be used to generate substitution text strings pairs; each pair consists of an actual text string and a replacement text string. Search Help for "Text Substitution Dialog" for more complete details.
Make a design file that you can attach as a reference into each sheet that contains your common texts. Then, every file will always show those texts, and they can be edited from that one design file.
MaryB
I solved this problem using nested reference file: thanks
