Hi I am using ABD SS4, I have attached some dynamic views (section view) to layout files.... below is the screen shot... the attached view looks great....
but when I print this elements go missing from the pdf.... I tries using Bentley driver and windows driver.... results are same.... below is the screen shot...
- duct on the right is missing
- the circular things got filled in
- door disappeared
- some beam sections are not printing correctly
I tried switching to cached view setting... but same elements were missing from pdf also disappeared from the cached view...
- all ducts disappeared
- door isn't there anymore
- in the pit, all structural elements aren't there...
I have checked all layers there visibility... negative....
please suggest a solution.....
Balkrishna
Try enabling "Rasterized" in the print dialog. Are you using a display style that is set to shaded? If so, you will need to use rasterized in order to get your output to look like the view. If that is not the case you may want to try the last version of ABD SS6 (08.11.09.866)
Thanks for reply. I will not prefer to print it in rasterized... Is there any way without rasterized printing....?
Would it be possible to send me a sample of your data to test here? If not, can you try the CONNECT Edition of ABD 10.2.0.35?
