Print Organizer
I have a pset that I created and used successfully several times. Now a bunch of the DGNs are missing from the pset. I tried creating a new pset with the same list of DGNs I had before and now it isn't recognizing the fence shape I entered for half of them, but does recognize the other half. I have confirmed that the shape is still on the same level and in the same place it always was in in all of the DGNs. Has this happened to anyone? What else can I check?
  • I have this at times working on a remote server. It does not happen by opening a working .pset and sheets are missing. It is when I am trying to add files to the set. Are you searching for a shape within the file to place a fence? Check that you are searching for the correct model & view. I also need to define the level, color, style & weight of the shape I am searching for and sometimes I even need to specify the reference file. If your shape is in a reference file make sure the Treat Reference As Element is not set on. At times I've had to do this a few times and with no luck then all of a sudden it works.
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
    Answer Verified By: Tamara Lynn
Reply
