How can I select all text nodes which starts with some words using desigN script.
I tried to use this statement but it did not work.I am trying to select all the label text which starts with "ETW".
if (characters .EQ. "ETW*") then color = 14endif
A text node is type 7, you may have to break into the element using header_type:
if ((header_type == 7) and (characters == "ETW*")) then
Only type may work... also the test on characters is case sensitive...
Answer Verified By: ERDAG KUCUKDEMIRCI
Thank you!. works like a charm
