I currently have an issue with Print Organizer not checking out dgn's from ProjectWise when printing.
There are titleblock attributes tied to the dgn's and during the printing process the Print Organizer does not check out the files to update the titleblocks. I have the variable MS_PRINTORGANIZER_OPEN_DGN_READWRITE = 1. During the printing process the error in the MicroStation Message Center is "No database connection is active at the moment." I have an active session of MicroStation and the pset is open from ProjectWise.
Please help!
Win 10
PowerGeopak V8i SS4 08.11.09.878
ProjectWise 10.00.02.265
Since there has been no response, should I post this on the ProjectWise side?
Sean, Yes, try the PW forums, outside of PW Print Orgnanizer doesn't have any titleblock-database connection Tom F
I've been working with bentley for a couple of weeks now on this and they have not fixed it yet. but, we did figure out that if you can open the pset with ss3 it works. has anyone fixed the ss4 for you yet? Looking for a fix.
Garry, no we have not found a fix for this. We are using a workaround using a script file that runs in the MicroStation batch process tool. This script basically checks each file out, updates the titleblock, saves the file, and checks back in.
