When I Try to print a drawing to PDF in V8i, It creates the pdf, but the objects are not visible in PDF
that is just way too vague a question without any data!
.. can you make a test dgn ( check it fails) , then upload here also your put your printer file that your using to make the pdf, please note what version of msnt your using and if your using sheet model files or just model space files... it is probably a setting your using or not using and element type but without being able to see , taste and feel your file it could be anything... you will need to zip these files to be able to upload then a s single file.zip use the insert to get the file added to the post
Lorys
