Issue running IPLOT with MicroStation CONNECT Edition Update 9 after Windows 10 Spring Creators Update was installed
I am seeing an issue with running IPLOT on update 9 which could be related to Spring Creators edition which i also just uploaded.  If I stop IPLOT from loading at startup then the file loads and everything is fine.  If you load iplot then it hangs.  I need to try update 9 on windows fall creators edition to see if it has the problem.
BTW - Spring creators edition is final and will be released this week. You can get your hands on the official release early which i have done.
