I am suddenly unable to use level overrides
the message centre says cannot modify library level attributes
is there a configuration setting which needs to be re-set
having this problem using microstation ss2 - 2d nested to 1
also had a similar problem using aecosim ss6 dynamic views nested to 3
Did someone change MS_LEVEL_EDIT_NESTED_ATTACHMENT_LEVELS? Editing of these overrides is disabled when working DWG-mode.
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
