I cannot get the default printer configuration file, printer.pltcfg to open. The debugging errors in Message Center read:
Cannot open printer driver configuration file 'C:\CorpApps\ProgramData\Bentley\Microstation V8i (SELECTseries)\WorkSpace\System\pltcfg\printer.pltcfg'
Unable to access default Windows printer
I have attempted to copy and replace the printer.pltcfg file from a colleague's computer. This did not correct the issue. Any ideas? I currently need the default driver to create and print a metafile.
Kyle Hord said:I cannot get the default printer configuration file, printer.pltcfg to open
With what editor or tool are you attempting to open that file? A .pltcfg file is XML text.
.pltcfg
I'm not attempting to open the printer.pltcfg with any editor or tool. I receive the error message when I attempt to change the printer driver from the Bentley driver to the Windows driver using the drop-down box within the Print dialog window. Here is an image of the Print dialog box and the error message received.
Kyle Hord said:I receive the error message when I attempt to change the printer driver
That seems a reasonable sort of thing to want to do. The message you posted tells us that there may be more information in the MicroStation Message Center. Do you see anything useful there?
I copied the text from the Message Center regarding the error in my original post. Copied again here:
A few things to look at here:
Rod WingSenior Systems Analyst
