win 7 pro
microstation connect edition V 10.09.01.01 update.9
https://translate.google.it
good morningI hope this is the right forumI use two plotting script designs"switch.dscript" works"if-then.dscript" does not workwhere am I wrong?
thank you
I attach scripts and dgn with levels
grazie
design script.zip
Comparing to one of my pen tables try eq instead of == for the level_name operative.
I am using == but apparently only following cellname.
Thanks for the replybut "eq" does not work
regards
