How can I convert multiple A1 format dgn drawing files to A1 dwg files, all in one go, using Microstation PowerDraft V8i please?
I haven't looked at PowerDraft in years, but I know that regular MicroStation has a Batch Converter tool under the Utilities menu. That would do the job, if you have that available.
MaryB
Thanks Mary, but my Utilities tab does not have the option of 'Batch Converter'.
I wondered...As I recall, PowerDraft is missing some of the tools from full MicroStation. I suppose you don't have Batch Process, either?
No batch process.
You may be stuck then. Those are the two tools I would use to process multiple files at a time. The only other way I know how to do it would be one file after the other after the other after the other...
Maybe someone more familiar with PowerDraft can come up with something I don't know about.Charge all those man-hours to the "I need real Microstation" project!
