Hello
I am having problems printing point clouds. My workflow is a s follows;
When I print the sheet the 'Rasterised' button is clicked and greyed out. The problem is that the printed output is always missing some of the rasterised point cloud content, regardless of whether I use Windows or Bentley driver (hard copy or pdf) the results are the same.
How can I ensure that all the point cloud is included in the raster files?
Paul
when I select a fence, then go to file>print and select a Bentley PDF driver and hit ... Printing point clouds (2D views) - Descartes V8i SELECT Series 6. QuickBooks support number
what do you mean by quick book support? Is there a way to view the point cloud when the Visual Style is set to 2D Wireframe.? should i do through my hotmail support number ? and i still cant understand what do you want to say quickbooks support
I think that's spam...
Is mise,
Paul Carroll
Point clouds can be printed without any issues regardless of how big they are
I just made a pdf for you to see as example
I am not going to say that ACAD is FAST printing prints with pointclouds becauce it is NOT but it is possible
Best is to download the pdf and view it directly on the pcThe previous that i uploaded was fast but to much client info
