I have drawings with a certain linestyle pictured below. When I print from the microstation print dialog the linestyle shows up how it is supposed to. When I print from the print organizer it prints as just a line with no style associated. I have tried changing the display setting in the print organizer and nothing works. The print driver/pentable for the print dialog are exactly the same. Any ideas on why this is happening? I'm trying to figure this out so all of our sheets can be printed from the organizer instead of having to do some individually. I've attached all relevant items.
In Microstation drawing:
PDFPDF
It would be helpful to know what version of Microstation and supply screenshots of each tab in PO. You are not giving us much to go on here.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
I know that, when Print Organizer opens files, it doesn't necessarily open the full configuration resources, so that text and linestyles might show up differently. I don't recall what version that was bothering me, or quite how I fixed it, but i know that I found the answer to it in the Printing and Plotting Forum
MaryB
And here's a Wiki article that may (or may not) relate to your situation:
https://communities.bentley.com/products/microstation/microstation_printing/w/wiki/14287/i-m-using-microstation-v8i-and-when-i-print-from-print-organizer-my-custom-line-styles-and-custom-fonts-are-not-plotting-correctly
Taylor,
Have you found an answer to this issue? I'm having the same problem. Thanks
God bless,
David
David Sullivan
Engineering Software Support Engineer
MS V8i SS2 v08.11.07.492
MS ORD-CE v10.09.00.91
Taylor did verify the Wiki article I linked above as an answer. Might that article apply to your situation?
