ProjectWise InterPlot Pro Connect 10.00.00.52. Linestlyes print as dots. Not reading variable IPLOTSRV_USE_POST_STROKE_LINE_STYLES = true
I cannot get the linestyles to plot when they are overridden by the design script to be screened back.  The linestyes just show up as dots.  I am using ProjectWise InterPlot Pro Connect 10.00.00.52.  When I go to the configuration file in interplot organizer, the variable IPLOTSRV_USE_POST_STROKE_LINE_STYLES = true is set which should fix my exact issue.  How can I tell what configuration file interplot is reading?  Is it being overridden by projectwise workspace?  If I use the print organizer with the design script the linestyles print as they should. Is there a new variable in the connect version of interplot?
