I'm running Microstation V8i corresponding to Power Geopak 08.11.09.878. I'm plotting to a PDF from a DGN that has many attachments--some displayed, some not. When I attempt to plot with all the attachments I want to display, the rasterized option is locked in and greyed out.
I have noticed this issue before, and because I don't know better, I had associated it with 3d models. I have two 3d attachments in this situation: attachments A and B. In this particular case, I need to detach only attachment A in order to correct this rasterized option lock. (It isn't enough to just turn off display on that attachment.) Attachment B can remain attached and displayed, and I can still disable Rasterized assuming attachment A is detached.
I've determined that it has nothing to do with presentation settings (i.e. Wireframe, Illustration, etc.). It isn't Plot as 3D (PDF).
Attachment A has a point cloud in it. Attachment B has linear, mesh, and I believe volume features.
Any advice on this? Where do I look for the correction?
It's the point cloud. Point clouds can only be printed in rasterized mode.
There was an issue in the past where point clouds in references whose display were turned off would still trigger the rasterized requirement, but that's been corrected in CONNECT Edition.
Answer Verified By: Derek Schmidt
im' in connect edition Up17 V10.17.02.61 and still have this issue. need to detach Reference wit point cloud in it.
