I have an issue that I cant seem to fix no matter what I try and google.
I have a Paper/Sheet Space with the current file referenced - and when I clip the reference the clipping extents then become printable.
Below is if the reference is turned on.
Below is if the reference is turned off.
As you can see the dotted line is the clipping line - no matter what I try I can seem to get rid of it - I am worried that the previous user has modified the configurations with microstation to always plot this - but I dont know where to look. He has since left the company and I am on my own with this.
Any help would be great.
thanks
John
The E in the circle is in the Paper Space - copied thru from the Grids in the model. I have then clipped the model with non-printable rectangle. I have also tried clipping using a fence and got the same result.
